Here is the one in my ex '70 GTX....Hopefully some others chime in as to which is definitely correct.
I'm not 100% sure, but are there different tailshaft housings - that would make a mounting difference.
Flange to the rear because of the aerodynamics. It improves air flow under the vehicle and creates a low pressure area that pulls the chassis downward at high speeds. Use the half nut on the bottom of the rubber mount to reduce steering wobble at high speed and negative harmonics due to the indexing of the universal joints. Be safe!Flange lip to the rear, mount nut to the front
Was going to mention that the flange had something to do with aero too lolFlange to the rear because of the aerodynamics. It improves air flow under the vehicle and creates a low pressure area that pulls the chassis downward at high speeds. Use the half nut on the bottom of the rubber mount to reduce steering wobble at high speed and negative harmonics due to the indexing of the universal joints. Be safe!
Nice, I got it right! Who wants to tell Justin that his car is wrong.....![]()
thats how my week is going. 12 days and still waiting for flange gaskets.
Or who was doing it.
