4mulas
- 11:21 AM
- Mar 16, 2017
- Just North of Great Falls
So, edelbrock says the 5090 heads will work with stock manifolds. Not to sure about that. Stock 69 hp manifolds. Passenger side 6 and 8 is the issue.
Went to run in the motor, 383 based, and it worked flawlessly for about the first 19 minutes, then started a periodic miss, which got worse. Shut er down. Next day went to diagnose things and the the #6 and #8 msd 90 degree spark plugs boots were near disintegrated from the heat of the manifold. Need to know if any others have had this issue and what you’ve done to combat the problem, straight boots that can be bent slightly? a different brand? I don’t know and only want to do this one more time. Any help is appreciated!!!
Issue is the angle plug on the heads point the plug too close to the manifold, I think anyway.
Please help
Please help
