67belvodere
Hey there
I've been searching this question for quite a bit and haven't been able to confirm it. Not sure if this is the right place to post it but I've exhausted most of my search areas...
I've seen that pre-65 b-bodies with a newer k-member will locate the engine rearwards and up 1.5" or so and there is much advice around that(for and against).
What I haven't seen is can you use a 1963-5 member in a 1966-up b-body? Would that place the motor forwards the same distance? Can it/should it be done? Or should I find a similar year v8 k-member for my '67 Belvedere?
