67charger383
Is there shims under the bearing on the pinion?
I think the shim is between the cup & the case not between the race & the gear....
You can put a shim in either location & have the same effect... Honestly I don't know why the shim isn't always placed between the cup & the case it would be so much easier....
Doing it that way really makes things easier......especially when you are starting from scratch.If you set them up on occasion its handy to have a spare bearing honed out to slip fit on the pinion to determine the correct shim thickness then press the new one on once you have the setting you need.
Pinion depth is set by shim between the big bearing and the gear. Pinion bearing preload is set with shims under the front bearing and pinion shaft where it seats.
done it that way too.But you can set pinion depth with a shim between the inner pinion bearing cup & the case.. It does exactly the same thing..
On a 742 shim goes between the rear (inner) bearing and the pinion head. No idea how you would do it the other way? Are you saying take the bearing race out and shim that? That would change the bearing preload possibly into a range of not being adjustable. Not sure how or why you would do it any other way than the factory did it.But you can set pinion depth with a shim between the inner pinion bearing cup & the case.. It does exactly the same thing..
Sometimes the lack of proper shims will dictate how it's done. And if you get the right pinion depth, it shouldn't make any difference in the preload setting shims needed. You move the pinion with a shim under the rear bearing or under the race. Either way, you end up with the correct pinon depth.On a 742 shim goes between the rear (inner) bearing and the pinion head. No idea how you would do it the other way? Are you saying take the bearing race out and shim that? That would change the bearing preload possibly into a range of not being adjustable. Not sure how or why you would do it any other way than the factory did it.
We had two of those at work....small and a large with the larger one having different yokes for small and larger bearings. Uh, don't think I ever knew what the square bars were called until now. Also had an oven that was never turned off. I bought a single burner hot plate for home use....When I worked for a major bearing supplier we used & sold bearing heaters like the one shown below.... notice the temperature setting in the lower right...
