69 N96 air cleaner bases.
Burns69RT
3:04 AM
Orange County, CA
Has anyone used the 440 air cleaner base on a 383 to run and eddy rpm intake and have the air grabber system? Heard the sat lower. If anything I know I could shave the base down where it would sit on the carb. Just figured it’d work better than the 383 base.
I just put my Bee together and used the 440 base for added hood clearance for the air grabber. I wanted to use the Edelbrock RPM also, but it is not possible with the ductwork. Ended up with a Weiand Action + and a 3/16" carb gasket and it fits perfect.
I’m curious if shaving down the carb hat on the base lower would allow it to work with the ductwork.
You have a long way to go. Also the round area that sits on the carb starts tapering out to a bigger diameter after a 1/2" or so. If you chopped off 1.5", what would be left will be to big to fit the carb. Anything is possible I guess, but I gave up messing with it. Maybe one of the cheap fiberglass bases could be modified easier, but those don't come with the carb studs either.
I noticed that about the fiberglass ones.
