1970lynch
Hey everyone!
I am starting to rebuild my first engine and look for an advise.
What I have:
383 B block #2468130-2
heads from 400/440 #4006452
stock pistons
stock crank
It was a decision made to bore the block to 4.280 after taking all the measurements.
That makes me to buy a set of new pistons and here is the question.
And at this point I started to think like it is a good moment to raise compression ratio on this combo.
So the main question is:
What way of increasing compression ratio would you recommend: reduction of the combustion chamber by cutting the heads surface or (if that is possible) putting dome pistons. Not sure if these ways might be equal by the output.
I know that might be written totally stupid but would appreciate if you can give me some direction to move.
What I have:
stock pistons
stock crank
