KidCoronet
Sorry if this topic has been beat to death but was hoping to get your advice on my specific situation.
I have a 8 3/4 rear with a 742 Cone style Sure Grip and just had the new style Green Bearings installed on the axles (thanks Dr Diff). I was hoping to avoid opening things up to remove the thrust block and have read that if using stock axles it isn't necessary with the new style Greens. Problem is the driver's side axle is ever so slightly short of seating properly - like just under 1/8 of an inch. I've verified that both sets of inner splines are lined up to receive the axles. I've tried whacking things with a chunk of wood and 5lb sledge to help things along but no go.
Am I missing anything here? Besides removing the thrust block do I have any other options to try?
Thanks!
Thanks!
