Heater Hose Installation
The Rebel
9:53 AM
SW CT
Hey guys do I have these on correctly?
If you want to go by the fsm, the hose towards the front connects to the driver's side of the firewall connection.
Thanks guys, I was looking at the diagram but it wasn't the best one. If the heat works just fine either way then I'll leave it for another day to switch them around to be correct, not like I'll be using the heat anytime soon, lol.
As I had to fix the leaking upper hose today I also switched them over as well. Glad that's now done!
Is your coil mounted on the inner fender? Is that the original location for it from the factory?
That's the way the car came from the PO. They were mounted to the intake at the factory.
