Disc brake advice
PolaraFury
11:00 AM
MN
Hello,
I have a 67 Satellite with stock original four wheel drum brakes. I would like to put disc up front.
I would like to get a kit for the job but I have no idea which one to buy.
Do I need one with a master cylinder and booster or can I use my existing original master cylinder
Any advice will be greatly appreciated
thank you
email Dr Diff for advice.
Hello,
thank you
I have a '67 Coronet 4dr. I used Dr Diff front kit w larger rotors for 15" wheels. I got new master cylinder and proportioning valve but stayed manual. I like the pedal feel of manual for me.
Hello,
thank you
You are definitely going to need a disc brake master cylinder.
I put a Wilwood kit on my 67 Charger because I didn't want to swap spindles and get an alignment done also my 66 Charger has Wilwood calipers so now they both use the same pads. If these cars were daily drivers I would probably go with more of a stock system.
The kits which say they work with 14" wheels work for road wheels but steel rims with hub-caps can still be a problem.
I did a Leeds kit. Went in easily, works great. I did power so I don't need to cram the brakes, all a choice. I'd strongly recommend getting the details on what parts they are using to make the kit, at least the rotors, calipers and pads. That way when they wear out you can replace them even if the company who sold them to you is long gone. Leeds uses '67 Mustang discs and calipers. Factory drum spindles.
Dr Diff is similar to late 1970s Aspen and Volare.
