1967 Slant 6 Coronet Convertible Project
s6convertible
New Member
6:12 AM
California
I've owned a 1967 Dodge Coronet 440 convertible with a slant 6 for about 17 years. It is driveable but needs restoration, which I'm getting ready to start. Over the years I've looked for other slant 6 convertibles for sale but I have never seen one. Does anyone have any idea how many '67 Coronet convertibles with a slant 6 were made? I'm sure the value isn't as much with the slant 6 as the more sought after big blocks, but does anyone know if the rarity of a slant 6 convertible (assuming it is relatively rare) adds value to the car? Thanks in advance.
Welcome from Alabama, I don't see any added value for the slant 6, but a very nice looking Coronet. Probably very economical in this day and time.
My oldest daughter will soon turn 16. My plan is to restore my convertible and her and I will probably share my regular car and the convertible. I have a 7 minute commute to work, so the convertible with the 6 cylinder will be perfect for getting around town. I figure why put money in to a car for her that will depreciate when I could put the same money in to the convertible and, at minimum, break even.
Below are my restoration plans. If anyone has any suggestions or resources, I'd greatly appreciate it! I know there's lots of info on the forum if I search, which I definitely will be doing as I start taking on the projects.
Needs minor body work and paint
Needs a new top (there is a hole in the top, it's faded and the back window is gone) - any suggestions on going with vinyl or glass for the rear window?
Convert to disk brakes
Rebuild engine if necssary
Add AC - a requirement if I'm going to drive it :)
I think most 67's started life with glass rear windows. Looks to be a very solid example for body and paint. Disk brake conversion I don't see as a must, just make sure what you have is working properly. Slant 6's just don't wear out, make a compression check to be sure and tune it up. On the A/C, I would look for a vintage under dash unit with maybe a modern compressor setup under the hood. Also plan on upgrading the radiator with the addition of A/C. My opinion, just suggestions.
My best suggestion is to rid yourself of that money pit before you get in too deep.
Just need your address, and I'll pick it up. :thumbsup:
Welcome to FBBO BTW.
Way cool car, enjoy!!
