I'm sure they've worked for some, and I probably just got a bum set...but your hood will thank you to not take the chance
Beautiful. Like a big piece of orange candy...Since my 63 is s street/strip car I did it a tad different even though its about 98% street. I got a steel eng mount off ebay for the drivers side and use a stock rubber mount on the pass side. I also use a chain on the drivers side just incase the steel mount would break which I dont think it ever will. Not much vibration at all from the steel mount and less worries about breaking it at the track. Ron
Yeah, especially the "custom" hood for clearance for the Weiand 6bbl intake and Air Grabber setup!I'm sure they've worked for some, and I probably just got a bum set...but your hood will thank you to not take the chance![]()
Well I think the only safe bet is a solid at least on the driver side. What some guys do is run a bolt through the stock mount, with a nylon locknut on one side and a countersunk head. Leave the nut a turn or two loose so it's not 'solid' per se but it will prevent any lifting when you're jumping on it. But, that means drilling through the mount bracket and/or K-frame so the nut has clearance.Order canceled per your advice.
I'm SO disappointed! It seems like such a good idea.
So what are the best mounts that won't rattle my windshield, but won't make me feel stupid for changing out motor mounts that aren't broken (regular rubber)?
I think I'm going to just bite the bullet and get the Mancini poly mounts.Well I think the only safe bet is a solid at least on the driver side. What some guys do is run a bolt through the stock mount, with a nylon locknut on one side and a countersunk head. Leave the nut a turn or two loose so it's not 'solid' per se but it will prevent any lifting when you're jumping on it. But, that means drilling through the mount bracket and/or K-frame so the nut has clearance.
I haven't installed the Moroso solids yet, but from riding in other's hotrods the vibration wasn't bad like people say so I'm hoping it works that way for me too!
Ouch, but cheaper than bodywork, and they shouldn't transfer vibration as bad as solid mounts.
Last time I went to poly mounts on the engine and transmission was my 89 Conquest TSi...went from "normal" sounding to nuts and bolts in a blender!
I'm liking these, and I'll call Mancini tomorrow since I can't seem to buy them from their website, my cart won't load.
Geesh! $219...
Geesh! $219...
My set up with stock motor mounts and a Schumacher torque strap. Works great. BTW I found NOS mounts, made in the USA. Later ones were more troublesome with breaking.
It's just puzzling that there were two companies out there making mounts and torque straps and all of a sudden, when you look for them, they're not available anymore.
Here's my Schumacher, modified E body kit I found on ebay for half the cost.
I was curious if you race your car or do hard launches with sticky tires ? I am wondering how strong that torque strap is if you use stock mounts with it and race the car ? It may be strong but it just don't look super strong to me but I could be wrong ? Ron
Good to know! Thanks a LOT!re-installed the factory biscuit-style on just that side, and BAM! Love it now. Took care of the extra annoyances, and with the Moroso mount still on the DS it's rock solid.
I have had the Mity Mounts installed as part of the QA1 K-member and front suspension installation, both sides.
I may go the way you have, when the time comes for the 541 to go in, keeping the Mity Mount on the Passenger Side. Nothing wrong with the factory style mounts that were on it, and I've done a number of burnouts and hard runs, WOT power shifting, etc, but I don't know how old they are, and since they had to be "touched" and I've added all of the traction aids, frame strengthening and stiffening and launch control, I figured now would be a good time. I'll ask the mechanic what he can come up with for now for a brace or turnbuckle/safety measure, and see what he says.
