FOUND 63-64 B-body AUTOMATIC Brake Pedal Bracket/Assembly
Rick@Laysons
FBBO Vendor
FBBO Sponsor
6:53 PM
Lakewood, WA
Feedback: 5 / 0 / 0
WANTED TO BUY.....
'63-'64 B-body AUTOMATIC Brake Pedal Bracket/Assembly...need the entire bracket assembly with pedal and all mounting hardware
Please email me with pics and info, and shipping cost to zip code 98499
rick@laysons.com
Can pay with PayPal....
Thanks,
Rick @ Laysons
We have one also, out of a 64 Polara, for a manual brake setup. Its in the other barn,
so I need to make sure its complete, that is if moparmark cannot help you.
THANKS!!!! for the quick responses!
Need an assembly for a car with manual brakes....
Whats the difference between the power and manual brakes ? Reason i'm asking is making sure i have the right one for my car . Thanks
Yes, if it's needed to do the swap out....
moparmarks...give me a call if you get a chance....877-930-4088 ext 102
Thanks!
Manual has studs for the master and power has holes. This in the main bracket.
Actually I'm wrong about this. True for 66 and up but found that 62-65 uses the same pedal assembly for both manual and power. The manual master has studs like the power booster.
I have found two different pedal lengths on 64 furys. Power brake cars have a longer pedal with an extension on top of bracket where they pivot from.
Can't tell from the back and forth if you're still looking or not. Pulled this one out of a 63 this afternoon. There is no brake light switch and it is missing one bolt to attach the lower of the two braces to the dash board, which I'd removed a long time back. One of the nut/washer combinations has come apart so it shows as separate nut and washer in the photo. Does include the wire bracket that mounts to the center of the reinforcing plate. I've assumed you want the master cylinder too. If not, I can remove the push rod and the line adapter from the front and refigure shipping weight. USPS shipping calculator looks like about $45 to ship what's shown. I'll take $50 for what's pictured, so $95 shipped.
Thank You!!! to each and every one of you who have responded to my WANTED ad!
I have the parts located, payment has been sent, and the deal is done!
Thanks!!! Again,
Rick @ Laysons
