dvw
3 pinion will hold up to 900 HP. Been doing it for years. When you make the swap use the front planet that came with the shaft you are using. It'll be fine.
ExactlyIn the case of the front planetary, the weak point is the splines, not the pinion count. 99% of the time the splines will strip out long before a pinion failure.
