727 b&m deep tranny pan
Nick ciavarino
2:26 PM
New castle pa
What is the correct amount of fluid needed after pans installed I drained the converter in which a little over 2 qts drained thanks nick
I installed a Summit deep pan on my 727. Added 1 quart to converter and installed, then filled pan until it said full on dipstick. Start and have on hand a few more quarts of ATF+4. Add as necessary. I think I was a bit over 10 qts total.
I presume you mean a new 727 deep pan install, and you drained 2 qts out of the converter? A 2" deep pan usually takes 2 more qts than stock. If that is correct, I'd start with 7 quarts, start the motor & slowly add couple more quarts, go through the gears, fill to the add mark, then check & add when it's warmed up. Depending on converter size, may be 9-10 quarts, if a 12" converter, another 1/2 - 1.
I looked it up b&m says it adds four qtr. ?
