I am curious if I could toss a rally dash in my car (1970 Sport Satellite with non-rally dash) without any modifications. In other words are all 1970 BBodies using the same mounting points etc?
Yes the whole shabang. Thats good to onow!Yes. As long as you are referring to the whole dash and not the dash cluster.
If the whole shebang includes the wiring harness, you are good to go.Yes the whole shabang. Thats good to onow!
Thanks, Yes I wouldn’t think the wire harness would be the same but good to get confirmation.If the whole shebang includes the wiring harness, you are good to go.
Not sure but the M&H harness for a 70 B bod, rally dash is available from YO. #HU272B, looks like it would be a worth wild investment. I just think it's unwise to rely on old brittle wires, electrical car fires are no picnic brother. A buddy of mines 66 convertible Impala SS, 396 4 speed burnt to the freakin ground cuz he was too cheap to replace the harnesses. He only had the car back on the ground for a little over a year after the restoration.....sad day for a chevy, even worse to see a grown man cry.I wonder if the harness is the same with the extra plugs for the Rally........
I’m sure you could make one work, but it would require some pretty significant reworking of the connections for the cluster since you would have to get rid of the round pin connector and redo all the connections with the proper plugs And probably some lengthening of the connections for the switches.I wonder if the harness is the same with the extra plugs for the Rally........
The two end supports and driver side end bar are the only supports on the traditional dash for mounting along with the five or six screws on top by the windshield.Also, any support brackets, as the rally "dash" might use more or different ones than the standard dash.
Yes for sure a new harness is needed.The OP said he was swapping the whole shebang and I think he confirmed that the dash harness was part of that shebang.
