73 fender tag decode help please....
bandit67
6:20 AM
Heart of Dixie.....
Guys , I have decoded some of these codes, but not all, can anyone help. I thought my car was a rally car , but no A 57 is there. I have front and once a rear sway bar, bulge hood with pins, and what I thought was the rally gauges....but no tach, don t rally pacs have tachs? The car was originally a four speed car someone had converted over to a 727. I m now thinking they stripped maybe a rally car for these parts as well as rear axle. thanks
It’s a lynch road tag/car and most of the info is not on the fender tag. You need the build sheet for that.
J54 I think is hood pins
Lack of a tach in your cluster does not mean anything. In fact, more cars with Rallye clusters do not have a tach than do have one.
D21 is your four speed.
Four speed and hood pins on a non-rally car would be super, SUPER rare.
Based on your tag, it's not a Rallye. But it could be on the build sheet. J54 is the Hood Insulating Pad. J45 would be the Hood Tie Down Pins and I don't see that on the tag.
Here's a decode for the 73 Charger Rallye(mine)
Code
Description
E55
340-4 Barrel 69-73
D34
TorqueFlite Automatic Transmission
WH23
W = Dodge Coronet / Charger
H = High
23 = 2 Door Hardtop
H3G
H = 340 240HP(net) 1-4BBL 8 CYL 5.6L
3 = 1973
G = St. Louis, MO, USA
141488
Sequence Number '141488'
EW1
Paint Code: White / Alpine White
H6X9
Trim Grade/Style/Color
H = High
6 = Vinyl Bucket Seats
X9 = Black
TX9
Upper Door Frame: Black / Black Velvet
B02
Date Built: 11 / 02 / 1972
201983
Order Number: 201983
V1X
Roof Type OR Color: Full Vinyl Top - Black
U
Built to Specifications for USA Order
A57
Challenger / Charger - Rallye
B41
Front Disc Brakes Some Yrs. Power
C16
Console w/ Buckets
C56
Bucket Seats 1972 up
G11
Tinted Glass All
G37
Left Hand Remote, Right Hand Manual Chrome Mirrors
H51
Single Air /w Heater
J25
3 Speed Variable Wipers
J45
Hood Tie Down Pins
J52
Inside Hood Release
J54
Hood Insulating Pad
M21
Roof Drip Rail Moldings
M25
Wide Sill Molding
M26
Wheel Lip Molding
M31
Belt & Hood Molding
N41
Duel Exhaust w/o Tips
N42
Chrome Duel Exhaust Tips
R11
Music Master Radio AM
V21
Performance Hood Treatment
V8X
Transverse Stripe - Black
CTD
Continue
With a Lynch Rd car you really need the build sheet to be sure its a Rallye. A57 is not typically on the tag in 73-74
Here's the best I found.
WH23:
Dodge Coronet,Charger
High
2 Door Hardtop
P3A: 400 260HP(net) 1-4BBL 8 CYL
1973
Lynch Road, MI, USA
122216: Sequence number
E68: 400-4 Barrel High Preformance
D21: 4 Speed Manual Transmission
TX9: Black Diamond Exterior Color
H6X9: Trim - High, Vinyl Bucket Seats, Black
TX9: Black Diamond Int. Door Frames
A03: Build Date: October 03
E31036: Order number
V4X: Black Top Color
J54: Sport Hood
Here is a pic of my tag. My car was built in St. Louis. The 340 was built in L.A. You can compare from my earlier post.
Rallye would get the hood code at least I guess if no A57 code ( LR cars )
hood pins and blackout ( V21 ) was optional, not part of the Rallye package, but hood is. Rear sway bar too.
Rallye cluster is not exclusive on rallyes, but also part of package on SEs.
but you got V6X Code... rallye stripe code instead.
I know in 74 several other cars could get Rallye stripes optionally, but can't recall if the V6X was just on Rallyes ( which I think it was just on Rallyes )
I'm just thinking out loud Thought
and if you think your car is U code, and 440s were just optional on Rallyes and SEs... is a plus on the code.
Not sure if the same stripe, but my 74 Charger SE has V7Y (Accent Stripes, Yellow). Not really sure if that was red fainting to yellow since I never actually seen a solid yellow stripe.
Or is the Rallye stripe the one up around the belt line since the doors were gilled.
Anyone of them codes for a half or partial vinyl top, it is black. Nacho was helping me with some of this vin a while back. My car has been repainted in its past using a semi gloss paint. The car was not sanded down as the wide side stripe and the rear deck stripe are still there. I assume the stripe was added later cause I just can't figure you could order a black side and deck stripe, and black vinyl top on a factory black car. Found the build sheet but is was only a few small pieces left, pieced together still was not much legible . thanks all
Is that second line number the number 28 or Z8.. So, to get a factory tach , it HAD to be optional code ordered, not standard on any packages....thanks
The V4X is for the black canopy vinyl top.
"28" on the tag = 28 inch wide radiator, common for big block car 73-74.
(Neato car, by the way!)
Yes, for the most part you could get black stripes on black cars.
I think that is a killer combination.
Subtle, yet powerful design statement.
