71 air grabber
mopar jack
11:36 PM
S.F. Bay area
Looking for an air grabber base plate for a 440/4 in a 71 Road runner. I am restoring my road runner and pulled the 383 for a later rebuild and replaced with my spare 440. The air grabber is all stock and I don't want to cut up the stock base plate so what are my options.
Not to many options. I would not cut the 383 one for sure... So you can Buy a 340/440 base plate or get a fiberglass one to use... I bought this fiberglass one a few years ago when a guy did what you did and no longer needed it but it was modified it.. I asked if he would separate the original steel lid and he said no you have the whole thing for $25... Kind of rude but functional and I really only wanted the lid..
I got the lid, couldn't stand the original pie tin. The four barrel lid has the best graphic by far.
Ok that is a 69 set-up not a 70-2...
You are correct the lid is 69 but the base is my original 71 383 with a slight mod of two studs to mount the lid. I will need a 440 base to fit under the hood.
