66 Sat
This might sounds like a stupid question...but how do I adjust my rear drums to be just dragging slightly with a Suregrip? I had both wheels off the floor and there was slight drag, but as both wheels are turning how do I know which drum is adjusted correctly? It's a '66 and has the spring that rides the adjuster (no self adjuster) and I'm finding I can only adjust them with the drum off as the spring needs to be lifted to turn the adjuster. I thought it must be the wrong spring but it shows this in the FSM. Should I just open the adjuster until I can just squeeze the drum back on and then see if both wheels still turn? Ignore the oil in the photo - this was taken before I fixed the axle leak - it's all clean and dry now.
