Exhaust Manifold Installation
tnfastback
5:24 AM
East Tennessee
Ok since this is my first ever Chrysler build and I guess the first Muscle Car build ever without headers, what is the best gaskets and/or sealant to use??
For manifolds just stock gaskets from the parts store. From the factory most of the 60’s mopars had no gaskets at all. Any warpage in the last 50+ years and that approach will leak though.
Use a straight edge on all surfaces first.
I had the HP manifolds on my Charger planed at a machine shop. I used all new studs and sleeve nuts, and a see-through thin bit of high temp anti-seize as a gasket. No gasket, just like when I took it apart, and no leaks.
I don't use any gaskets, just Hi-temp RTV sparingly.
A colleague of mine insists on using RTV on his cars as well. Unfortunately, GE's Silicon RTV 108 (red color) high temp, is only good to approximately 450° F. The metal temps of the cast iron manifolds approaches 600° - 650°F, so after about 2-3 weeks, the leaks reappear. I've suggested that he have the manfold sealing surfaces checked for flatness and corrected if not. My friend just glops on more RTV and keeps on going.....oh well. I hope you have better luck....
BOB RENTON
BOB RENTON
Good point. A straight edge should tell you enough. If you can fit a .005 feeler gauge under it you’re probably too warped for no gaskets. Gaskets will likely work up to .015 or so. After that, plan on a quick fly cut on the mill.
not to high jack, i know he asked about a gasket and sealing the manifolds for leaks but if he's going to use new hardware to mount the manifolds i believe some of those go into the wet areas, maybe some one could advise the OP and myself on what kind of sealant should be used on the ends of the studs or bolts to prevent the coolant from leaking.
I have always used "Yellow Death" weatherstrip adhesive. It keeps the studs from coming out when you remove the nuts. I have used it since the 70's.
(3M Weatherstrip Adhesive, Yellow)
Also use Anti-seize for future tightening
One tip to prevent leaks Is to check the bolts after a couple of heat cycles Do this a few time until they are staying tight
BOB RENTON
My manifolds are warped so I put on a thin coat of high temp RTV. no leaks for 4 years now.
BOB RENTON
I've been doing this for several years now and have to experience a failure. I believe the key is proper application.
1) Apply RTV
2) Assemble
3) Tighten nuts to snug
4) Wait 60 minutes
5) Torque to spec
6) Re-torque after a few heat cycles
1) Apply RTV
2) Assemble
4) Wait 60 minutes
5) Torque to spec
My colleague has progressed in a similar fashion..... but to no avail. I believe that the exhaust manfold sealing surfaces and perhaps the head's mating surfaces are out of flat to the point that resurfacing is the only option. If the head's surfaces are out of flat, this involves a teardown. BTW....the application is a '70 Chrysler 300 Hurst with a 375 HP 440 TNT engine....the exhaust manifolds are of a different configuration, especially the driver's side.
Thank you for your insight.
BOB RENTON
I will check the manifolds trueness with a straight edge for sure. The heads being new shouldn't be a problem, but I will check them also. Thanks everyone for the suggestions and help.
