Mike Szadaj
- 5:59 AM
- Jan 17, 2019
- St. Clair Shores, Mi
1968 Coronet RT, 440 basically stock except for mild cam. When building the engine and car, my buddy gave me a Mopar OEM dual point distributor. Got the car on the road last August. This year the engine started running rough. I took off the distributor cap and saw one set of points was fried. Not very good mileage for brand new points (especially when you have to consider the car was not driven during the winter). Please tell me if this is the correct procedure for setting dual points.
1. Adjust both sets of points to a gap of .014" - .019" with feeler gages
2. Check dwell both points together (37' - 42')
3. Disconnect one set of points and check dwell of the other (27' - 32')
4. Reconnect those points and disconnect the other set and check for dwell (27' - 32')
5. If necessary, readjust gaps until all 3 dwell readings are within range
