Other then the inner fender servo bracket, which I believe is the same for 71-74 B/E bodies, most of the components are the same B/C/E-bodies, and probably even up into the mid late 70's.
I currently have the wiring harness, the turn signal stalk, the cable clamp, and the bracket that bolts to the master.
I believe all I need is the servo, throttle cable, speedometer cables, and servo bracket.
I believe there is another bracket that bolts to the intake that I need as well.
I have several pieces including a B-Body BracI'm looking for a Servo Bracket for my 72 Charger Cruise control. Also interested in any other parts associated with the Cruise Control system. Thank you.
Let me know if any of these parts work for you.I'm looking for a Servo Bracket for my 72 Charger Cruise control. Also interested in any other parts associated with the Cruise Control system. Thank you.
