Leaking Fuel on Corners
Jason Savedra
12:17 AM
Oregon
I am noticing a large amount of fuel leaking out through the fuel cap on my 67 Satellite. It is a locking gas cap. I guess my question is that is there a fuel cap that will stop the leaking?
Have you made sure your vent lines are not stopped up? Also what is the condition of the seal on your cap? It seems to me, it's a uphill battle to be leaking at the cap on a 67 Satellite. I think the system has to be pressurizing the tank to force fuel out at the cap. 67 Satellites have no return line to the tank unless modifications have been made, also there are to many other connections for a possible leak other than at the highest point in the system. A little more detail on how and when you are experiencing this would help.
Does it only do it when you have a full or nearly full tank? If so, it's probably the gas cap seal.
Yes, at both levels. The rubber seal is in good condition but I do not think that is the proper fuel cap. Is there a recommendation for a non-locking gas cap?
When cornering fuel runs down the side of the car around the fuel filling area. I will definitely check the vent lines. The gas cap is vented also.
The stock gas cap was not vented on the 67's B bodies. Is this something that has started happening or always happened?
I think the gas cap needs to be vented with a single fuel line setup.
If you pump fuel to the carburetor the volume needs to be replaced by air.
Also when you fill the tank from an underground tank the gas is cold and then as you drive the car you blow nice hot air under the car.
So you generate vapor and pressure in the tank, with a non-vented cap where does it go?
That's why in my first post I, asked if the vent lines were checked. The 67 B bodies have an elaborate vent system and can use a non vented cap since the tank is already vented.
Plymouths and Dodges are different. Plymouths have a small vent to atmosphere at the top of the filler neck, but Dodges don't, and require a vented cap.
So I bought this set up for the satellite, i figured it might be an upgrade. My concern is that i may be short on Hardware to complete the install. Does anyone have a diaphragm of this by chance
Thinking my locking cap was not sealing on my 63 Fury, I replaced it with a tight one. Then...on a hot day, full tank, fuel leaked out of the sender hole, which had been tightly installed. I went back to the loose, locking cap, no leaks up hill, and no pressurization any more.
