diesel_lv
I installed front discs, rebuilt rear drums w wheel cylinders, new aluminum 15/16" master cylinder on '67 Coronet. Work great. Except slowly get squishy and get to no brake at all after about 2 weeks. No fluid anyplace. Tried all suggestions, loosen then tighten all connections, bleed again etc. Emailed Cass at Dr Diff. He recommends 10 lb Pressure Relief Valve for rear brakes. Has anyone here ever had to do this and if so, did it work. Not real keen on cutting brake line, flairing both cut ends and adding valve. Thanks
