68 Charger Inside Door Poly
Macdon221
11:22 PM
Winnipeg, MB
Good Day,
What was the factory way to attach the poly that goes inside the door between the metal and the cardboard door panel?
I know the poly goes screwed in at the top by the chrome trim...
Is there white rope caulk used down the sides?
Just wide black tape (like duct tape) on the bottom and the plastic tucked in?
Was there anything used in the middle under the poly to keep it in place?
Good Day,
Yes there are dabs of Butyl in the recess area around the arm rest area n in the recess area towards the front of the door by the door handle.Send me a PM IF you need pics
Is it just the black tape at the bottom or also strips of rope caulk down the side?
Place strips of this between the poly and the metal where you need to keep it in place.
