440 from 71 Cuda fit into 70 coronet
Did that to a few in the past. When Cudas and Challengers were being scrapped.
a 440 is a 440 is a 440 no matter what it was put in. the only things that change are the exhaust manifolds, mounts , water pump housings and oil pans.
That must be a 440 Six-Barrel if it came from a Cuda 71.
would a 440 from 71 Cuda fit into 70 coronet, thanks greg
The 440 will May have to mess with a few things. They did a front mid and rear sump on the oil pan. I am putting a 72 motorhome in my 73 charger Had to switch from front sump to mid. Also mine had a 318 in the charger so may have to do some k frame and motor mount work.
thanks for the info
