Not as many Speed Shops as you'd think...I see you are in Indiana. Lots of street racers there which means lots of Speed Shops which also have repair facilities, or know of muscle car repair shops. Get your work done by these kind of shops. They most likely know how to set the timing, set your carb and make it work properly.
Wow - kept your car for a YEAR?? I hope they're closing up and not moving...
Damn!!!!! Just saw this post!!!! Thank You!!!!
Big block water pumps are not different between New Yorker and Charger. Or Plymouth for that matter. They may have more or less impeller blades due to A/C or non A/C but will fit the water pump housing. In 1973 Chrysler changed the Big block water pump housing and relocated the outlet from the driver side to the passenger side but the pump itself is the same. (something to do with smog pumps)The radiator was problematic last time it ran, it was overheating that was where the problem started. Someone else on another forum said the Water pump on a new Yorker is different from the one on a Charger. Could changing the water pump fix this?
As stated you owned the car for a few years n than the over heating problem started,so you took the old rad out n tried to replace it with a BE COOL UNIT,the old rad core was probally just wore out n as long as the tanks were in good shape the rad shop would have no problem recoreing it,n you would of be able to pop it back in the same as you took it out,after all it kept it cool for several years.The rad cores dont last forever n once the fins start to become loose on the tubes its on its way out n it doesnt help from not using the rite mixture of anti freeze in there.Ok so I bought my 70 Charger in 2010. It was born with a 383 2BBL and the previous owner replaced the 383 with a 440 from a 75 New Yorker. After owning the car for several years it started to overheat so I bought a radiator from Be Cool and tried to replace it my self but didn't have the space or proper lighting in my garage so I gave up and sent it to a shop near by. They had it over a year before they tried to do anything with it and then when they did they told me it was the wrong radiator. I took them the radiator that was in there when I got the car and they told me they'd make something happen. They're now telling me they can't find the right radiator and the car has to go home because the shop is about to be torn down because of interstate expansion. One of the issues we're having is that the radiator that was in the car has both hose port on the right hand side, and we can't find any radiator that has that setup, they all have the upper hose port on the left and lower port on the right. I'm super stressed out about this and don't want to have my car towed home only to have it towed somewhere else again. I'm open to any insight I can get here and I'm in central Indiana if anyone knows of somewhere in my area that can help. Thanks.
sounds like a fake story. Way too much idiocy going on from beginning to end.Ok so I bought my 70 Charger in 2010. It was born with a 383 2BBL and the previous owner replaced the 383 with a 440 from a 75 New Yorker. After owning the car for several years it started to overheat so I bought a radiator from Be Cool and tried to replace it my self but didn't have the space or proper lighting in my garage so I gave up and sent it to a shop near by. They had it over a year before they tried to do anything with it and then when they did they told me it was the wrong radiator. I took them the radiator that was in there when I got the car and they told me they'd make something happen. They're now telling me they can't find the right radiator and the car has to go home because the shop is about to be torn down because of interstate expansion. One of the issues we're having is that the radiator that was in the car has both hose port on the right hand side, and we can't find any radiator that has that setup, they all have the upper hose port on the left and lower port on the right. I'm super stressed out about this and don't want to have my car towed home only to have it towed somewhere else again. I'm open to any insight I can get here and I'm in central Indiana if anyone knows of somewhere in my area that can help. Thanks.
I wish it were fake...sounds like a fake story. Way too much idiocy going on from beginning to end.
I come from FABO, and we have the same problems between the 69 and down spigots being different than the 70 and up, but with the SBMs.
But I want to talk about diagnosing the overheat first.
From the beginning of this thread, I have not seen the diagnostic that condemned your rad.
An overheat below ~30mph, has a different solution than an overheat above ~35 mph. And if you have A/C, there is a third diagnostic.
If you knew this, and did the proper diagnostic, to arrive at a bad rad,well then;
IMO, I would work with the new rad, which you already paid good money for, and just swapping to the later WP housing and hoses. You may have to install a new TDC mark on your balancer, which is no big deal.
