Brake question,blowing out lines
davek
10:58 AM
columbia SC
So I was replacing front pads and 1 caliper was bad ,piston not going in. Decided to replace both with new. I have a new MC so what the heck might as well replace that. Now my question is can I blow out the lines-get out the gunk. Will the air blow threw the portion valve or do I need to unhook that? Thanks Dave
I would unhooked every single connection and spray brake clean through everything. Then blow it out. Take the splitter/prop valve out and clean it separately.
Sediment “gunk” will not form in the lines only in components. Bench bleed master then bleed brakes till clean fluid.
Happy Motering
Happy Motering
This is called a brake fluid flush. recomended by new car manufacturers. easy to do and cleans everything
Brake fluid is hygroscopic and the lines rust out easily. If it was me I would replace all the hardlines. It's easy enough to do and I know it gives me piece of mind with all the tailgating going on in todays driving.
Just my $0.02.
