Universal joints.....
Durandal25
6:48 AM
Texas
....so.....thinking this going to be a tad more simple than it's turned out to be.....but are the universal joints for a 67 Coronet 8/34 a crap shoot? I pressed out the rear one, and scored a NOS TRW 20059 unit.....but is seems a bit larger than the one that came out. Is this a front unit? Needless to say......I may need an opinion on what I should press back in there....
If it's a large u-joint (3.625") should be a 1330 cup diameter 1.0625".
If you have the 7290 joint and caps, you can replace the 7290 cap with the 1330 cap.
The shaft is not that big
36333DB6-BCD0-4AF5-B714-0482FBA3782D.jpeg B39C4A10-F370-42CC-B55E-BF4F5F4B6D66.jpeg 3078FE09-78D2-47D7-8D8A-009322876705.jpeg
Shaft 2660635 1967-68 2.75 52.00 727 8-3/4 318 383 Belvedere Coronet Charger
lol....going to take the original over to NAPA and get right one.....lord I'm a dip-****.
So my U-Joint dimensions are as such
Bearing Cap Diameter Axis 1 (in) 1.078
Length Between Inside Snap Rings Axis 2 (in) 2.125
7260 (Dodge) 2.125 1.078 All 4 caps
So, I just picked up a few at the local auto store only to find out they are incorrect also. I need a set that’s 50mm between the caps .
Here’s one of the u
MM' what is that in English ?:DCan't calipers in pic's. Did the yoke get tweeked in removing u-joint?
looks like I need a set of
Dana Spicer 5-3228X or 5-789X
I'm not reading 50 mm on that caliper. It is approximately 54 which is 2 1/8"
....been a long day for Durandal25. He clearly sees that he's been looking way too close to the issue. More beer is required.
I’m really confused
why are the sizes for these u joints still off? This time MOOG 246’s 7620
7A2B5BAB-D21A-4B36-BD5F-ECAF771791F2.jpeg DDC1C067-790A-41DA-838E-36EA0AACF5F7.jpeg
I put new ones up to the yolk and they don’t fit either.....at a total loss
