- 11:12 PM
- Apr 13, 2012
- Granite Bay CA
For those of you that have stumbled into my thread about the build of my wrecked 1970 Charger XH, I am rebuilding the original 383. The crank and pistons are in and yesterday I started to install the cam.
It is a Comp Cams 270/470 Magnum series.
I was slathering on the cam lube and as I was smearing it on with the cam lobes in my right palm, I felt some rough unfinished edges that cut my hand a few times.
Take a closer look. You will see at the edges of the lobes, some fabric remains where I used a towel to clean off the lube.
These spots are right on the outer edges.
That one above was the worst.
The lifters ride along the middle and edges of these lobes. I thought of just taking a file to the edges but what if I cut through the hardening treatment? Why should I have to do that anyway?
I haven't seen this before. I've installed maybe 20 cams over the years and this is the first one that I have seen like this. 7 of the lobes have sharp, raised edges on them.
Of course everything else came from 440 Source, so inside my engine its like a few Americans living in Chinatown
