62 Leaf Spring Replacement
w.Hudson
5:11 AM
South Louisiana
Who has a replacement leaf springs for a 62 B body ? I don't want anything that will raise the ride height like the Mopar heavy duty replacements that have an one inch over stock ride height.
Anyone offer a stock style replacement ?
67-76 A body should be the same as a 62 B body. Maybe a nice set of springs for a 340 car would work nicely ?
Thanks !
Call ESPO, in Pennsylvania. They just made originals for my '63, but I went with the HD, instead of the stock. 7 leaf vs. 5...
That is kind of what I am thinking. Get a set like the later 440 cars had. 5 on one side and 7 on the other.
Is that what you did ? Or 7 on both sides ?
456/457 super stock springs, the pic is the high side, with the extra half leaf
Driver side, about an inch lower.
I am wondering if you have made any decisions on your leaf spring replacement. I am looking at doing this on a 62 Fury. Here is information relevant to doing so. I know relocation mounts can also be used. I am wondering if those would work well with the longer B body springs to not make such a drastic height change in the rear. All personal preference. I don't mind the slightly jacked aggressive stance, but I also think a more factory rear height is cool.
Hi! wounder about Hotchkis Sport Suspension leaf springs 24385 Geometry Corrected 1.00 in for A bodys same segment for B body 1962, 20 35 55.has anyone tried them?
I have decided to get the P3412002/03 springs since they are the same length as stock. They are rated 3000-3200lbs. All the info I am finding indicates the ‘62 should right in that range. If they don’t work out right, I know someone else with an A body that will be more than happy to use them.
