Wheel and tire fitment Torque thrust Ds and 67 Belvedere
Belvedere One
6:04 AM
Phoenix, AZ
I'm considering changing the the rear wheels and tires on mine and looking for examples of what tire size fits when using a 15 x 7 torque thrust D with 3 3/4 backspacing. The 8 3/4 is stock width and wheelhouses are all stock.
Let me know your thoughts.
On my 66 Coronet I went with 235X60X15 on TTD's. Absolutely no rubbing ever and I put lots of miles on it. You might be able to squeeze a 245 on but I know the 235's work for sure. Stock 1966 XHD springs and torsion bars and the wheels were 15X7.
On our 66 Coronet, we had Torque Thrust 255/60/15 x 8" rims, and had some rubbing on the inside.
Went to 235/70/15 on 7" Torque Thrust, also rubbed, but now on the outside. Had to change the tire to 215/70/15 no rubbing now (we like tall back tires) The issue is the 7" rim has less backspace, so for us in the the future 8" w/ 4" backspace is the way to go, good luck.
I am running a 15"x7" wheel with a 4.25" backspace and a 225-70-15 tire on a '67. Although it is a little close, I do not have any rubbing issues. Your 3.75" backspace would move the wheel 1/2" CLOSER to the wheel lip. In my opinion, that would be too close for comfort unless your tire was narrower.
Dont want tire rub at all thinking different back space on the front
My Wife and I are building to suit her style The back rims are 235/70/15 Nothing Stock about a Stock
Kinda want to keep things centered
Check out a member on this site using lemonwedge as his forum name I believe he's running the wheels and tire combo your asking about
Thanks for the replies. Im currently running an 8" Ramcharger style steel wheel with 4.5 of BS and a 255-60 M/T ET Street radial which fits in there fine. I was hoping to hear that at least a 235-60 will work which it sounds like it will based on Runcharger's experience. There is no custom BS options on the American Racing Torque Thrust D's, otherwise this would be a piece of cake.
Yes: That's exactly why I did what I did. The 235's were as much as I could get on the front and I wanted the same size all the way around too. You can definetly get more tire in there but those wheels are what they are. One thing about it, I wanted the 60's-early 70's vibe so they gave that.
