- 3:34 AM
- Nov 24, 2015
- Moreno Valley, So California
742 with the better clutch type Sure-Grip as opposed to the cone style Auburn type.
the 742 case uses much larger pinion bearings than the 741 case -- so unless you want to machine your 741 pinion bearing pockets out to 742 bearing sizes ,,, but why bother ,, finding a 742 case is not hard -- although there is nothing wrong with the 741 case
742 case pinion bearings HM803149 / HM803110 --i.d. 1.750" ,,, o.d. 3.500"
HM89443 / HM89410 -- i.d.1.312" ,,, o.d. 3.00"
741 case pinion bearings HM89446 / HM89410 -- i.d. 1.375" ,,, o.d. 3.00"
M88048 / M88010 -- i.d. 1.312" ,,, o.d. 2.687"
The 742 never used a crush sleeve, that was new in 69 with the 489 case.The Mopar factory used a solid sleeve but the aftermarket makes a crush sleeve. If you have the '742 professionally rebuilt, insist on the solid sleeve. I specified the solid sleeve and as I reviewed the build before they shipped it back, I asked which sleeve was used, they said crush so I had them tear down to meet my build requirements. Unfortunately, one cannot inspect the crush shield, so I hope I got what I asked and paid for.
The '742 was the performance differential until the '489 came along, so use it in good health.
For safety, get a US Car Tool driveshaft loop:
http://store.uscartool.com/Bolt-In-Driveshaft-Loop-64-72-Mopar-B-Body-70-74-Mopar-E-Body_p_21.html
