- 5:13 PM
- Jul 1, 2015
When I took the alternator to the shop a few weeks ago when this first happened, they said it tested good and I asked if that includes the diodes and they said yes. But I really wonder if they would check for such a small drain. Do you think if I leave the battery disconnected between driving, it could still lose voltage? I will try it. Also, I noticed, after driving 11/8, the battery was at 12.77 on 11/9, at 12.7 on 11/11 and dropped to 12.0 on 11/15 (4 days later). That's a big drop in only 4 days. I need to monitor it some more. Thanks for your help!
I would have been specific as to what tests were performed and the results of those tests. "It tested good" really does not say anything without any specifics. Such as: forward resistance of the diodes; the reverse resistance of the diodes (each diode tested separately); resistance of the the stator windings (each phase separately and each to ground). The round back alternator has an internal capacitor connected to ground from the positive diode common connection and the output stud to ground. Capacitors develop leakage to ground over time, similar to what you are experiencing. This capacitor can be disconnected without any problems.
Yes....disconnect the battery and see what its voltage drops to over a few days. IF the battery's terminal voltage drops significantly, it is POSSIBLE that the battery has a bad or sulfated cell, causing the voltage to drop. Sulfation can occur any time and is not time dependent. If possible, measure the specific gravity of the electrolyte in the battery....the cell with the lowest specific gravity is the sulfated cell. If not possible, perform a load test of the battery.
BOB RENTON
