elonblock
- 11:53 AM
- Feb 15, 2012
- Eastern Shore Of Maryland
I started out with a 1966 Belvedere and designed it to look like a 1967 GTX, using modern drivetrain, brakes and suspension, etc. This was created with the intention of being a daily driver for my wife. So reliability and high quality were a priority.
The car started out fairly solid. It was acid dipped and all of the sheet metal, body work and paint prep have been professionally completed by one of the nation's top restoration shops. The trunk has been finished in a durable smooth bedliner type finish.
The body and sheetmetal is currently in primer. All of the sheetmetal and doors have been mocked up, gapped and are ready to bolt on.
All of the drivetrain, suspension, brakes, full exhaust and accessories have already been mocked up. The A/C lines and A/C system have all been mocked up. The A/C lines are hidden under a custom cover. The front and rear suspension has been mocked up with the wheels and full exhaust.
Basically it's at the point where you can choose your color(s) and bolt everything together.
Link to restoration before and after pics:
https://www.flickr.com/photos/restomodrods/collections/72157633268157332/
Here's what's included:
ENGINE: Brand new SRT 6.4L Gen 3 Factory Complete Assembly Line Engine with computer management kit and wiring harness, all mounts, brackets and accessories, pulleys, starter. 475 horsepower.
TRANSMISSION: 5 speed Tremec with shifter, trans mount, clutch master cylinder, clutch slave cylinder, all lines, clutch, pressure plate.
RADIATOR: New Classic Radiator
EXHAUST: Full TTI exhaust kit (includes headers, collectors, pipes, mufflers, mounting hardware and exhaust tips).
A/C: Classic Auto Air Perfect fit A/C kit, including new compressor, all mounting hardware, and brackets.
WHEELS: 17X7 Billet Magnum 500 wheels, with all mounting hardware.
SUSPENSION:
Alterkation front end
Street Lynx 4 link rear suspension kit
Wilwood Hydro boost 11" brake kit
Stainless Steel brake lines
Moser HD axles
Wilwood emergency brake kit
ORIGINAL EQUIPMENT: GTX front and rear seats, including buddy seat, with brackets and GTX trim
GAS TANK: New Quanta Gas Tank, straps, insulators and fill neck.
8 3/4 Rear axle assembly
MISC PARTS INCLUDED:
New reproduction GTX hood scoops
GTX gas cap door and new trim ring
Various new lenses and trim pieces
Manual shift Steering column
Dash reverse light
Power steering cooler
Complete wiring harness
NEEDS:
Seat covers
Door panels
Headliner
Carpet
Rear carrier
Driveshaft
GTX trim
Tires
Dash and gauges
Body hardware kit
Bumpers
Glass
Body, window and door seals
Wiper motor
I have a clean Maryland title.
80% of the hard work has been completed. Over $90,400 invested. Best of everything.
The body and all parts are located in western Pennsylvania. Approximately an hour from Pittsburgh.
ASKING PRICE: $36,000
Thank you for the ad.
SUSPENSION:
Moser HD axles
Dash reverse light
NEEDS:
Seat covers
Door panels
Headliner
Carpet
Rear carrier
Driveshaft
GTX trim
Tires
Dash and gauges
Body hardware kit
Bumpers
Glass
Wiper motor
