School me on Cam degreeing
joe smith
7:55 PM
Florida
Is it to......
A. Check if the timing gears and chain is off?
B. Or if the cam itself is made wrong?
When you degree a cam you are checking top dead center of #1 piston, but what if other lobes are not correct?? School me please
Both are reasons to degree. A little off on the crank keyway, a little off on the sprocket...it all adds up. That's the "tolerance stacking" people talk about.
It's also done to know where your installed centerline is, if you like/need to move the cam timing around.
As far as other lobes being off? I'd say it's pretty unlikely if the #1 pair check out, but if it's a concern you could degree every cylinder...
This was always something that I just couldn’t figure out how to do.
Your finding true TDC with a stop or dial indicator. Once you have that your just matching up the cam card. Some manufactures have different ways to check. Like @.050 lift. I also took two old lifters and tig welded the rod ends together to make a nice surface for the gauge to ride the lifter bore.
Ive done a few now and only found one that I felt needed some advance.
There are some great videos on YouTube on how to do it. If you have the tools and equipment it really doesn't look that difficult, but I think it is much easier with the engine on a stand.
I was going to ask how would one do every cylinder but a degree wheel would make that possible I assume....
Want to check all the lobes? Quick and dirty. Set the cam up with no advance. At TDC#1 the intake and exhaust lobes will be perfectly level with each other. The #6 lobes will also be level, but at a different height than the #1 pair. Rotate 90 degrees. Check #8 & #5. Rotate 90 degrees Check #4 & #7. Another 90 degrees. Check #3 & #2.
