19 69 GTX
- 3:59 PM
- Apr 30, 2016
Well it's for real this time it has to go. I cant wait the 2.5 years my wife is in school to work on it. I spent some more money on some parts because I dont have the patience lol and that lead to an argument. It's not worth the stress so I'll just wait till she is done and pick something up then. Was asking 8500 last time out but asking 9500 now as I found a nice solid hood , front and rear bumpers that need rechromed, transmission core for rebuild 727, trans cross member, another 65 K member with a manual steering box as well all newer steering components and Lakewood Racing shocks as well as the coupler for the manual box. Also found a standard bore 440 early 73 block with steel crank , balancer , oil pan , timing cover , water pump housing and windage tray. Car has all the body chrome plus extra pieces. Also just got new seats from Gary Ball and new brackets. Car comes with new Auto Meter gauges and a 5 inch tachometer with shift light. B&M ratchet shifter as well as a new 2 core aluminum radiator about 600 bucks for it. Has new door gaskets, trunk gaskets and cat whiskers. Just had the newer style green bearings installed on the Moser axles. Car has 8.75 sure grip in a 742 case with super stock springs on offset hangers. New 3/8 fuel line from fuel tank. Has drum brakes on all four corners with all new components as well as all new lines and new dual master cylinder with adjustable valve. 9500 takes it ir may consider trades for a daily driver car or truck. Almost forgot but as you can see from pics frame has been tied as well. Can get pics of other parts. PM me for more information located in Terre Haute, Indiana
