themechanic
Oklahoma is OK
- 12:32 AM
- Nov 11, 2012
- Moore, Oklahoma
This isn't the A body forum.our cars top out at 3600 lbs or so
This isn't the A body forum.![]()
Sorry, I overestimated but damn close with 1/2 a tank of gas in them!This isn't the A body forum.![]()
Sketchy at best I will do jack and stands then some nice comfy carpet for the create.Chances are there'll never be a failure in the field to be sued over and they're also not a certified lift to start with. Give thought to the heaviest thing you'd ever put on a 2 post lift.. our cars top out at 3600 lbs or so. This is the heaviest thing I've ever put on my made in China 9000 pound Direct Lift (Rotary Lift's "off brand".. Rotary's are also made in China!) without any issues.
Coronet Super Bee 3,396 (Coupe)
Coronet Super Bee 3,381 (Hardtop)
Nice but would you be under thatChances are there'll never be a failure in the field to be sued over and they're also not a certified lift to start with. Give thought to the heaviest thing you'd ever put on a 2 post lift.. our cars top out at 3600 lbs or so. This is the heaviest thing I've ever put on my made in China 9000 pound Direct Lift (Rotary Lift's "off brand".. Rotary's are also made in China!) without any issues.
Memory fairMy memory was the hard tops were heavier than coupes.
Stop typing in code... WTF is sketchy about my certified lift ??!!Sketchy at best I will do jack and stands then some nice comfy carpet for the create.
Its all gravity on this planet.Sorry, I overestimated but damn close with 1/2 a tank of gas in them!
Shipping Weight, lbs. (Approximate, not for licensing)
Charger (base model) 3,305
Charger R/T 3,575
Depends upon whom did the certification. Test lab or manufacture? From the vid you may not want to overload a manufacture rated lift by to much. If I caught it correctly it was overloaded by 5000 lbs.Stop typing in code... WTF is sketchy about my certified lift ??!!
