wagonman
- 10:27 PM
- Aug 1, 2015
- Deming New Mexico
Howdy folks, I just converted my BB from points to a Mopar style conversion. Ran fine with the points but I had the EI laying around so I wired it up and slammed it home. BTW this is one of Boggers Hi Rev 7500 units. So No spark is the issue. I used a jumper from the starter sol post to the run side of the ballast just to take all wiring out of the picture still nada. While removing thr jumper I heard snap like spark jumping. I pulled the coil wire off the cap and repeatedly touched the ballast with the jumper. Nice hot spark on Both sides of ballast while doing the little trick. I ohms checked the pickup a at 350 ohms and rechecked the reluctor gap with a brass feeler. Suspect the PU is NFG. Can I test it with aDVOM set on the A/C scale and get a reading while cranking? Thanks Wagonman. PS I have one in my 68 440 and it runs fine for 7 years also swapped that module in just for SNG.
