Lisle double flare tool
I would agree Fran, but sometimes the cheap Lisle tool is just not beefy enough to remove a really stuck WP.
Ya thought about that after posting that. Just looked up difference in price in Lisle tool $15 used $35 new or a quality one $63 I'll spend the extra, thank you very much.
I got that Lisle flare tool yesterday. Tried it on some old line and some new line. Very satisfied with how well it works.
Funny thing - I also received mine also yesterday.
Haven't had a chance to use it.
Appears really stout
Thread revival here. So, looks like the Eastwood brand is the best flaring tool? Would the hydraulic be any better? Sorry, I'm new to these tools.
Sometimes you stumble upon a tool and when it works, you stop looking at any other tools. There may be some other way to go but this Eastwood setup works fantastic. I have yet to make a bad flare and have to redo it.
I have the hydraulic tool but have looked at the Eastwood setup as well. I will say this that the hydraulic tool produces some of the best flares I have ever seen and they do not leak. That said, there is a learning curve as you can smash a flare if you really bear down on it which might be true for the other tool as well. The one thing that I like about the Eastwood deal is that you can bench mount it, the hydraulic requires 2 hands to operate in the "as delivered" state, however I did build a mount for it which I can put into any vise. The other things in that the hydraulic is portable so you can use on a vehicle if needed, although I will admit that this is easier said than done.
If my hydraulic died and I needed another flare tool I think I would go hydraulic again even though I like the Eastwood system. The hydraulic is more versatile and IMO more consistent (although I admit that I have not used the Eastwood version). I bought dies for normal brake lines as well as AN fittings so I am set. Not cheap but the product it produces is fantastic.
Thank you all this definitely helps. So, Eastwood it is at this point unless anyone else has a suggestion?
