65-440
- 8:27 PM
- Dec 2, 2009
- virginia beach, va
Don't go back, figure out the problem! Go back to baseline adjustments on the carb, disconnect all hoses and plug the vacuum ports on the carb. How far out are your idle mixture screws?Alright, Ive re-torqued and if I spray the base and the manifold with brake clean it doesn't seem to shoot up in RPM anymore, but it still wont idle in gear. Hoped it was my problem, but it seems not so. Probably will go back to my 2 barrel. I'm building a 383 for it anyway...
. I now have no coolant (?) and the engine is definitely crooked, thinking motor mounts and probably needs a u joint.
