- 1:20 PM
- Apr 13, 2012
- Granite Bay CA
But they are ALL the same, right? OP just needs any old 2 groove, right?
Well whats he looking for ?Thats a 66-67 style pulley
He hasn't specified.. Said "They are all the same"...Well whats he looking for ?
I found one that came off a 71 383. im assuming it should will work since my 383 is a 68?
As long as ur top pulley isn’t to big. KimI found one that came off a 71 383. im assuming it should will work since my 383 is a 68?
that crank pulley that came from that 71 383 worked just with my 68 383.which l knew it would both steel cranks and big block pulley.l lined it up with the a/c pulley l had on.bolt holes lined right up as well.thanks for the advice on here everyone makin sure to get right crank pulley.The bolt pattern might have one bolt hole that needs to be elongated... Don't make the mistake of just forcing a bolt in, it never ends well...
Supposedly the change occurred in 72 but I've seen it on some 71's...
