Need help identifying side marker bezels
hunt2elk
10:47 AM
WI
These came off my 69 Road Runner and would like to confirm if they are correct. 2930757 is 1/4" deeper than the 2930753. I see repops are made, but only the shallower version and listed as being the same for front and rear. Anybody know if I have 2 that are wrong and that all 4 should indeed be the same?
Definitely have to be 69 parts as the 70's on the Dusters and Runners and such that looked similar were all lit up and had the center hole for the bulb. Just a question if they are A body variants or B body Plymouth/Dodge housings......I am sure someone who is into P/N's more than me will pipe up soon and have the exact fitment. I think the more important part is that the contour of the housing fits flush to the panel more than the depth of the back as all 4 of them are placed into an open hole letting them sit flush either way correct? I am trying to pull some info from Memory on my 70 Duster as the front fender ones seemed to not sit as flush as the rear quarter housings lens wise. I wonder if it has anything to do with the backing plate that holds them on being deeper or different shape that goes against the quarter panel on the inside vs the front fender?
Hunt.....edit to my original post here's some info on an older post I have attached. he says the fronts are deeper than the rears housing wise. I remember the same on my 70 Duster I believe. Two were deeper than the other two.
https://www.forbbodiesonly.com/moparforum/threads/wtb-1969-roadrunner-side-marker-housing.82389/
They are correct according to the 69 parts catalog Joel. I have a fender 2930757. The mopar replacement part number is 3420601 and also 2932926. The quarter panel 2930753 is replacement part number 3420608 and also 2932928.
Google search points toward the 757 being the front, and 753 the rear for a 1969 RR. I have seen this difference as well only to find out there are several different bezel housing for different cars.
That is the best answer I have now.
D
Did a little digging for you and Tony's parts lists the 0757 as the front assembly and from another post another forum the 0753 is the rear set.
And there's the answer while I was digging.....good info to know and stash for lata use!
:thumbsup:
The parts manual I am working from is dated January 1971 which explains the replacement numbers being in there. I now have a mission - find a 1969 dated parts manual!
D
D
Don’t rush to buy another 69 catalog D. I know there are 3 or 4 out in my garage. Wait til the weather warms up a bit and I will see if any of them are 69 print versions. If one has 69 print, I am willing to do a trade.
Thanks guys. And here I thought 2 of the 4 were wrong and I would have to find some more. I'll use what I have.
Interesting.. I was gonna say the deeper ones were Dart rears, as I bought a pair of each to do the Bee and then was told all 4 should be the same. Hope that's correct on a Bee.... lol
Yeah, I checked my Bee out before asking the question. That car has 4 of the shallow versions. Although I can't be certain those are correct as that car came to me in boxes.
And by the way Wayne, I believe you have one of those elusive 69 parts manuals that you scored from Tom? Beat me to it buy a couple of hours. Either myself or Darrin would take that off your hands if you don't see a reason to hang onto it.
I actually looked at my 4 x OE bezels today and they're all the same shallow ones. As for the manual I think I'll hold onto it, would look funny if I jumped from '68 to '70.. LOL. Tom made mention that he may just have another in his stash so would be a lot cheaper getting his if so.
Dart rears are in fact a different part number.
Sure seems odd that in 69 a Super Bee would use all 4 the same, and a Road Runner would have deeper ones on the rear. You would think just for added cost that Mopar would have kept it simple and used the 4 same ones on each car.
Interesting. I also have all 4 shallow on my Bee. Time to head to the fender stash and get a look.....research continues....
D
