Throttle cable recommendations 64 Polara
Odmark91
Sweden
Hello! I have installed a new engine in my Polara wich is a 505 stroker rb with a edelbrock Victor intake. So now the carburetor sits much higher and the stock throttle cable is too short.
I made a temporary extension that sort of works but i need to replace the cable and do it properly, i dont want anything to have a risk of binding or popping loose.
So im asking for recommendations on what to buy, is there some kit that fit the stock pedal or do i need an aftermarket pedal as well? Lokar seem to have good cables?
Its a 4-speed so i dont need a kickdown cable, just the throttle one.
Appreciate all input.
did you measure the required length?
Something like that here could fit
https://www.ebay.com/itm/324491853756
I havent measured the lenght yet, but around 24" seems to be about right when using a high rise intake.
That one looks good, but i would prefer something that i can buy directly here in sweden, i would like to install it within the next week.
I have tried to research this a bit myself and from what i understand the lokar cables fit the stock pedal if you remove the clevis pin, does anyone know if this is true?
I just bought one of these. Very nice. Made a simple bracket at the carb. Even in the position its used in this application I cut aprox 8" off. Instead of the rubber spacer at the gas pedal I made one from brass. Cut the threaded end down for full travel. Slant 6 is the longest or factory cable.
https://www.amazon.com/STAINLESS-BRAIDED-THROTTLE-CABLE-KIT/dp/B004YFAFCA
That looks identical to the Lokar cable so that should work for me as well, ill get the 24" variant and shorten it. Awesome, thanks a bunch!
I just went through the same deal. I bought a 24.5 inch throttle cable from Rick Erenberg on Ebay. Fits great.
They fit
I had a similar siuation wih my 65 Bel. I am using an M-1 singal plane wh a Holley. I ended up with a 24 inch cable, and an extended height adjustable cable mounting bracket. This setup also allows me to use up to a 1 inch carb spacer, if I choose to. It all came from Mancini.
View attachment 1094684View attachment 1094685View attachment 1094686View attachment 1094687
Thats what I use the Lokar cable. Good thing is the bracket that holds it bolts to the rear carb stud so it will be at the right height. I have had the Lokar cable like that on my 63 since 2006. Ron
