ordered the fastfish rear seal. i hope its a quick job.
watermelon
watermelon
watermelon
My patented "seal stretcher". I'll sell ya one for $100. Actually, I may see an opportunity here...I'm gonna put a hinge on one side of a seal and call it "one piece". My snake oil sales have been kinda faltering lately.how does one get it over the crank flange?
Just read this resurrection quickly, but why on earth would you bother to make a one piece seal and then cut it? We put one piece seals over Lycoming prop flanges all the time, IN ONE PIECE, why would you cut it. Spring is removed, seal stretched over and allowed to relax, spring reinstalled and seal glued in place in the crank snout.
Oh I'd love to see someone try that on a BB Mopar!![]()
I believe it, I just can't see a Mopar-type rear seal stretching like that let alone returning to shape enough to get a good seal (most seals have metal inside the rubber--ain't happening!). Been so long since I've seen a rope seal I can't comment on that one...The propeller flange is a larger diameter than a BB crank hub. I remove all the prop locator nutserts before I do them, but if these guys can wrangle a seal around 6 of them and successfully install I don't see why it can't be done a BB crank flange.
Hell airplane parts are cheaper than MOPAR parts...![]()
No problem I hear u I myself bought a new seal retainer from Mancini and can’t agree moreNo disrespect Snakeoil, but I think this seal solution is snakeoil. They want you to simply "cut" the seal so you can put it over the crank. You can't slice a seal with metal inside for rigidity without making the diameter smaller. I do not see this working out too well, and it is the latest and greatest solution with no longevity and reliability testing. I have been building motors for a long time, and I can not remember when I had a rear main seal leak on me. If you install the seal properly, and are careful, you won't have a leak. I don't feel it will work well.
An experienced Mopar guru is needed to properly install this seal. On a Wed. At 75 degrees. At sea level. At three in the afternoon. Pacific time. Saw this in MCG magazine.
Think this is it.Custom Performance Engine Seals | Fast Fish Auto PartsWhat happened to the Fastfish guy ? He never came back to FBBO?
There is no metal in this type of seal.All rear main sets (Fel-Pro at least), come with a white plastic strip. You place the small end between the seal and block at the main parting line. This will prevent the block from shaving the back side of the seal when you rotate it in. As themechanic suggests, you use a punch or screwdriver (CAREFULLY), and push the seal out. Using the method I described above, you rotate the lubricated seal back in. Put the lower seal in the seal retainer as normal, and install it.
As Garys1969RR postulates, I agree that the leaks emanate from the improper installation of the side seals. Fel-Pro doesn't include them in their set for some reason, but rather RTV and 2 pipe cleaners. I think they removed them because too many people didn't know that you had to soak them in mineral spirits so that they would swell after installing them. If you installed them dry, they will leak. Properly used, you work quite well. I throw away the pipe cleaners, and either just fill the void with RTV, or get the Mopar Performance Rear Main kit P4271691:
http://www.rosevillemoparts.com/pro...-and-big-block/cPath/166_169/products_id/4290
The side seal shown are the old style, but the ones included are rubber. I still used RTV to ensure a complete seal.
They want you to cut the seal, twist it open, and spiral it onto the crank. Not only does that have an effect on the steel in the seal, but you have to remove the crank to install it. If a problem does crop up, you can completely destroy it getting it out, and put the PROPER seal back in.
Yes there is. It has a steel spine just like OE seals do.There is no metal in this type of seal.
No 'g' in Cummins....Thisis a great idea, I think it is a cummings double lip seal for Diesel Engines. If you have one or bought it let me know i will track it down. This should sell for maybe 22.00 to 25.00 max. I need you to mic it and look inside the seal for the production number. paying 79.00 is expensive..
