Can Someone idenyify this planetary
Not sure, it appears to be a 727 low/medium performance 3 pinion planetary. HP versions mostly were 4 pinion.
No expert but I wonder about those casting chipped out areas around the roll pins? Here is mine which was a 727 4 gear pinion. I wonder if instead of NOS that it's been dissassembled and somehow rebuilt. Think I would pass - but again I'm no expert. Might PM DVW for his opinion.
https://www.amazon.com/photos/shared/Gu3sorqPTnqvLasbgRofgg.cwc_aJ3HiqDJvn9dPRwYbA
I replaced mine with a new 5-pinion planetary due to excess wear on the back shoulder that increased end play. 5-pinion is overkill but it appeared to be the best new product I found at the time. It took care of my low-gear whine.
https://www.amazon.com/photos/shared/RfmLQ3JHTeCkDxLBd72zyg.vPxLqLyM3wtUAcId8PO7sG
DVD is clearly an expert on 727's. Not sure why he prefers the 3 pinion, but he knows his stuff.
The PN I have for the 65-up 727 rear planetary is: 2466539. Now the 2801180 could be a superseding number, I don't know.
I believe those areas allow easier oil access to the thrust washer.
For posterity, before the ebay ad expires:
