Mocajava
I have a 69 Coronet with a 383 stroked to a 496, with a new wiring system for the entire car. The battery is mounted in the trunk with a heavy cable running forward and through a cutoff switch. My compression ratio is about 11 to 1 and gage reads about 13.7-14 amps while running. She starts fine when cold every time, I have a Holly Sniper EFI system on it. The issue is after running the roads, just normal driving for about 30 minutes and getting to 195 temp. When I shut her off I can't get her started again...she only makes about one to two sluggish revolutions and acts like battery is drained. The battery is new, isn't all that large but seems to be drained. If I wait an hour to let everything cool down, she cranks right up again very easily. I realize the battery in the trunk takes more drain just from the resistance of cable over that long route to starter, but the issue seems to be the heat of the engine. I have double checked all the connections and confirmed all are tight. Could it be that the battery isn't big enough to provide enough amperage when hot and the compression ration is slightly higher when the engine gets to operating temp causing my starting problems? I am thinking about getting a larger battery which provides more cranking amps but wanted to get some expert opinions before I spend more cash chasing this problem. Thanks for the help Gents! Mocajava
