Moparmann
I just installed C.B.'s Plug & Play Headlight Relay Kit and now, for some reason, my headlight doors will not function. I cranked them open manually, but they won't close or do anything. Apparently, once you crank them open, they're open with no way (short of disassembly?) to close them. I'm getting 12.5 volts at the connection to the motor. The last time I used them, the doors worked fine, but I had an issue with the headlights randomly flashing, so I disconnected them. Now, after replacing the dimmer switch, the headlights work fine! I had a water leak into the headlight relay of my first Charger, and the doors would close, but not open. The current appears to be intact and undamaged. Any advice you could offer would be truly appreciated! I hope the motor hasn't just died!!
