Moms68
I’ve had issues (collapsed) with the Comp hydraulic lifters in my 340 and want to replace them. Does anyone have experience with Howards or Lunati hydraulic flat lifters or another recommendation??
Get them from someone that will verify theirs are made by Hylift Johnson. (USA)
I'd start with Jones Cams/Denver NC.
Hughes sells Johnson lifters too.Get them from someone that will verify theirs are made by Hylift Johnson. (USA)
And I've read quite a few. I picked the ones for my Roadrunner, to replace whatever (stock?) lifters were in it. One collapsed and pumped back up, but when it or another collapsed, it didn't. Changed pushrods, lifters, springs, locks (10°) and retainers. Worked with Mancini and CompCams on the selection. They have allowed me to experience the full power of my 440 6bbl as it is.I have heard more complaints about Comp cams lifters than any other brand.
My confidence level isn’t very high for any of the currently available “non-specialty” hydraulic lifters...... but when I have to use them, I go to the effort to get the Hylift Johnson’s.
From what I can gather, they are the last of the American made “normal” FT lifters for a Mopar.
Good call--they're worth the extra few bucks.View attachment 1108745 Couldn’t be happier!!
Direct from Top Line Auto Engineering, MI ph. 800-441-1400 ask for Dave ext. 611Good call--they're worth the extra few bucks.
If I may ask, where did you end up buying them?
How much did those set you back?Hylift Johnson is located here in Michigan and is a division of Topline Automotive, it's all the same company.
