- 10:07 PM
- Dec 23, 2009
- Rancho Cordova, CA
I am putting up for sale this Poly 318, factory cast iron, 4bbl, intake manifold, #2206384, for the Carter 4bbl AFB carburetor.
And selling the Carter AFB carburetor 3249S AM1 that was on this intake manifold.
You will get all the bolts, brackets, coil mount, thermostat housing, temperature switch, heater hose and vacuum fittings, that are on this manifold.
I took all this off a 1957 Plymouth Savoy, and didn't leave anything behind, off the donor car.
As i mentioned i took all this off the 57 Savoy, but the carburetor codes out to be a 1962 Poly 318 Carter 4bbl.
I cleaned the manifold off all the grease and grime off the top side, and bottom side.
Now it's ready for the buyer to paint it whatever color engine paint of your choice.
I will sell the manifold with all the miscellaneous parts as i described in the above sentence at $450.00.
If you wan't to also purchase the Carter AFB, i will sell that separately at $125.00.
I am willing to break up the parts.
The carb is being sold AS IS condition.
It does look in damm good condition.
Give it a try as is, and see if it works, or if not, give it a rebuild.
You have nothing to loose.
Now lets talk about shipping and payment.
This manifold weighs a ton, and is a ball breaker, and hernia getter in lifting it up.
If figure easy 55 pounds, maybe a bit more, packaged up, ready to send.
You will be expecting a hugh shipping quote, so don't fall out of your chair when i look up a quote to your zip code, and tell you what it will be, from me here in California.
I use FEDEX, and send with insurance on the package, and a signature delivery at your end, when the FEDEX driver rings your doorbell.
Now for how i expect to be paid.
For something this expensive i prefer a US postal money order, cashiers check from your bank, or i accept Pay Pal, Family or Friends.
And if an in person, local pick up, cash in hand, hundred dollar bills will do just fine.
Any interested parties, please talk to me thru this forum in a private message, and i will get right back with you.
Thank's a lot.
Jim V.
hemi71x
Thank's a lot.
Jim V.
hemi71x
