John Tipps
I just replaced my stock heads, cam/lifters and are using roller rockers and followed(I thought) all the instructions on the components, made sure several times the timing was set and plug wires were delivering to new plugs TF recommended and it runs awful, the timing must be at least 20* advance to run but its shaky and on the road there's no power (or any more than before) and it cuts out while pulling at 30 mph. I've tried moving the dist gear both ways and of course it just got worse-could it be the rockers/valves?
Heres what I did...
Installed new cam and chain, made sure dots were at 12 and 12 o'clock
Measured before and cut 440 source pushrods so rockers were hitting middle of valve stem,
Shimmed roller rockers for side to side clearance
Rotated engine to get 0 lash on each valve and then 1 turn on each then tightened
Finished assembly and did the 2000 rpm for 30 min ( it was running badly but the rpm,s were up so it wasn't noticeable)
Any help would be appreciated, this has become an expensive nightmare and it shouldn't be
Heres what I did...
